Secvest 2way Erfahrungen
07-07-2010, 21:19
RE: Secvest 2way Erfahrungen
hi nichtbeimir,
maybe you know, but only for shure, every motion detector is equipped with a flap inside to avoid an alarm due to a cat or other small animals. If this flap is not fixed enough (maybe an assembly error) and will go down itsself you might mask animals without knowing it. Nevertheless you are right, the motion detectors seems not very attentive but you have to consider that this might avoid wrong alarms and in doubt you have to implement an additional motion detector to monitor a greater area. I recommend to use only a small number of motion detectors and monitor every room with break contact on the windows, they ar more reliable, best regards skyline - Abus Sevest 2way mit verdrahteter Euro Kompaktalarmierung - Kopplung mit EIB Powernet über Secvest Universalmodul |
Secvest 686 oder Secvest 2way | kofrank | 9 | 8.222 |
27-04-2015 07:41 Letzter Beitrag: kofrank |
Secvest 868 Komponenten an die Secvest 2Way? | Gjila1 | 14 | 10.657 |
22-06-2014 18:18 Letzter Beitrag: Gjila1 |
Erfahrungen mit Funk-Fenstergriff FU 8435 W / 350 E | SecvestUser | 3 | 4.404 |
22-12-2013 22:15 Letzter Beitrag: Xerox |
Secvest FU8000+ Bewegungsmelder Erfahrungen | holterwok | 2 | 3.929 |
16-08-2013 18:34 Letzter Beitrag: frky |
FU 8230 Secvest 2Way Funk-Innensirene für Secvest 868 Funkalarmzentrale ??? | Danny | 9 | 12.071 |
01-03-2013 18:40 Letzter Beitrag: Alarmservice-Hamburg |
Secvest 2Way; Erfahrungen | Chris G | 0 | 4.837 |
16-03-2012 07:54 Letzter Beitrag: Chris G |
