Response time for Abus 2WAY motion sensors
28-11-2013, 21:28
Hi all,
I've installed the Secvest 2WAY in my house incl. motion sensors (PET) and magnetic contacts for windows. I've tested the buglar alarm when entering the house after a day at work, and also done "walk tests". The magnetic contacts react almost instantly. The motion sensors are very hard to trigger. Both in walk tast, and in real-life. I can often walk right by one without it triggering. The motion sensors are installed according to the instructions at approx 2,3m height. Any advice? |
28-11-2013, 21:51
RE: Response time for Abus 2WAY motion sensors
Manual page14:
"Note: When delivered, the sensor cover may be set in the lowered position. Check this as a possible cause if the sensor does not detect any movement. Attaching" |
28-11-2013, 21:56
(28-11-2013 21:51)techniker28 schrieb: Manual page14: Yes, I've read that as well. I paid special attention to that line. I've compared the photo to the sensor's inside, but I see no match. I simply cannot see any possible way the cover can be in the lowered position. The thing/plastic that can flip according to the picture is not in my sensors. empty. |
29-11-2013, 08:13
I'm writing from my smartphone, so only a short note here ... Don't use PET motion sensors, this is pouring money down a rathole! They cause you exactly the mentioned problems! Is your PET a cat, just forget motion sensors. All they do is set off the lower area of the controlled area. If there is a fly above, cats will jump! The second thing is that a unwished person is able to get or creep through the sensor controlled area very easily. M.
29-11-2013, 12:14
(29-11-2013 08:13)Mega X Sicherheitstechnik schrieb: I'm writing from my smartphone, so only a short note here ... Don't use PET motion sensors, this is pouring money down a rathole! They cause you exactly the mentioned problems! Is your PET a cat, just forget motion sensors. All they do is set off the lower area of the controlled area. If there is a fly above, cats will jump! The second thing is that a unwished person is able to get or creep through the sensor controlled area very easily. M. What? That can't be correct? I mean - then the alarm system is untrustable?? |
02-12-2013, 07:07
No. There's a lack of knowledge at you side. A professional would never use movement detectors in areas where pets move.
In this case you got to make sure that your first "firewall" - the detectors at the windowfront do the job. I secure those houses with a sensor that detects the breach of glas, too. The detectors from ABUS provide the possibility, to attach those sensors. Then them have to be put on the Window -rim. Not at the side, guess why Regards, M. |
