Terxon MX 8-Zone Wireless Extension
30-06-2019, 11:31
Hello All
I have an interesting problem.
I have MX setup with two extensions Wired and Wireless.
They work well and no issues with fitting or setting them up.
About 3years ago i added two FU8305 wireless panic buttons.
The setup was very easy and the wireless range was very good, so no issues.
I ran a test on the buttons over 4 months ago, and the Alarm Unit returned an error.
TELECMD LOW BATT, and the keypad showed a RED light.
I cannot CLEAR the error.
Is there any way to CLEAR the error without replacing the panic buttons?
(I have tried and failed to replace the batteries in the panic button) I have removed the panic buttons by de-paring them off the system.
The Alarm unit is OK, I can still ARM and DISARM However I always see the error and the red light on the keypad.
There are NO other issues with the setup, no other error events in the logs.
Any advice?
14-09-2019, 12:23
RE: Terxon MX 8-Zone Wireless Extension
All.. I have reset the TELECMD LOW BATT fault. Here is what i have learnt.
1. The downloader software will NOT reset these types of faults
2. Disconnecting (removing the from setup/memory) the wifi devices i.e FU805 from the wifi extension unit will NOT work.
It seems the wifi extension continues to send the last fault to the control panel. So I disconnected the extension unit from the system, the control panel returned another fault (Extension 2 missing). I had to reconnect the extension and that cleared both faults.
Good news i no longer see the RED fault LED on the keypads.
(I guess one question : i dont recall a configuration setting for the number of extension units so why did the control panel see the missing extension (i only disconnected the power from that unit) I suspect its the wiring method as I was unable to reset that fault. Hence i had to reconnect the extension unit before it cleared)?!? Any thoughts?
14-09-2019, 17:29
Hi
I can't answer your question but thanks for giving that Feedback to us.
Regards
Sektionschef
Instar IN-5907HD
  Terxon MX kein optischer Alarm wenn Zone als EA konfiguriert ist wfischen 2 63 27-04-2024 15:05
Letzter Beitrag: wfischen
  Terxon LX - Anzeige der auslösenden Zone Wombats 9 862 08-12-2023 21:32
Letzter Beitrag: Donald
  Zone für alle Bereiche, A, B, C, D, auf NV stellen Delago17 2 1.343 01-03-2023 09:09
Letzter Beitrag: Delago17
  Zone Sab auf alle gruppen vanturenhout 29 5.597 25-12-2022 12:44
Letzter Beitrag: ssb-security
  terxon mx gehtest: zone schlägt nicht an tombalabomba 15 3.844 03-09-2021 18:48
  Terxon S zone 4 offen Ohk1985 14 5.201 17-07-2021 09:00
  Fehlalarme in einer einzigen Zone Terxon M Vogels 27 6.980 26-11-2020 12:50
Letzter Beitrag: Berggeist
  Terxon MX - Benutzer Rechte nur für seine Zone Westice 23 10.076 30-03-2020 08:03
smile Terxon LX per App steuern. Wie schaltet die Zone? Terxonsebas 22 10.685 25-09-2019 12:40
Letzter Beitrag: Terxonsebas
  Terxon S Zone C aktivieren - wie? trybear 8 5.469 06-05-2019 08:16
Letzter Beitrag: Sektionschef
